Nov 01, 2018
09:21 AM
Nov 01, 2018
09:21 AM
I want to try TLV over I2C with RaspberryPi. I have got the following guide which mentions how to start communication.
Just a question that weather smbus or smbus2 supports all the operations needed for data transfer in the form of bits or bytes?
Any other suggestions?
10:17 PM
Apr 10, 2022
10:17 PM
Hi @User15938 ,
Yes you need to install smbus for communicating to the TLV493D using RaspberryPi via I2C
You need to enable I2C, in Interface Options by using sudo raspi-config on your terminal window.
Then install smbus using following commands:
pip install smbus
sudo apt-get install -y python-smbus i2c-tools
Thanks and regards,
Yashraj
10:17 PM
Apr 10, 2022
10:17 PM
Hi @User15938 ,
pip install smbus
Thanks and regards,
Yashraj
