We are using the TLE493D-W2B6 in one of our products, and came across "short-range" mode in the data sheet, however were able to find little information on how to set it in the user manual. How can we enable short-range mode and what are the parameters short-range mode should be used for?
The TLE493D-W2B6 can be configured and short-range sensitivity can be configured with the following bit which is readable and writable:
You can find the short-range bit on page 12 in the User Manual here https://www.infineon.com/dgdl/Infineon-TLE493D-W2B6-UM-v01_01-UserManual-v01_11-EN.pdf?fileId=5546d4....
