Measure CO2 When It Matters - Infineon’s XENSIV™ PAS CO2 now comes in SparkFun Red. Check it now!
RAM_MARSAKATLA
Distributor
5 questions asked 10 sign-ins 5 sign-ins
Dear Team,
What is the right fit suggestion for Rollover sensor from Infineon for 2-Wheeler EV Application
Adithya_S
100 sign-ins First question asked 50 replies posted
Hi @RAM_MARSAKATLA ,
There are few recommendations of the sensors.
If you are willing to measure the position, then Infineon's 3D position sensors are appropriate choice. Please check our 3D sensor's portfolio.
Also, if you are willing to measure angle, the Infineon's angle sensors are appropriate choice. Please check our Angle sensor's portfolio.
Hope this helps and resolves your query.
Thanks and regards,
Adithya
Adithya_S
Thank you for reaching out to Infineon Technologies.
Please mention the parameter which you are going to measure with this sensor.
Thanks and regards,
Adithya
RAM_MARSAKATLA
Distributor
Hi Adithya,
Thanks for your response.
This sensor will be used in Electric Vehicle. When an accident has happened to vehicle, Based on the sensor feedback whole system should shutdown.
Adithya_S
Please share the design where you are willing to add sensors. Also, mention whether you are tracking angular movement or position movement to confirm vehicle roll over.
Thanks and regards,
Adithya
Adithya_S
Thanks and regards,
Adithya
Adithya_S
I hope your query is solved. We are closing this thread.
Thanks and regards,
Adithya
