M agent for TLV493
Measure CO2 When It Matters - Infineon’s XENSIV™ PAS CO2 now comes in SparkFun Red. Check it now!
kinetic
our new product is using a TLV493D.
We are using it as a angle sensor at the end of a shaft. We are using a N45 4mmx10mm as per one of your user manuals.
We have discovered that this magent has a magnetic force of 1.3T, however the  TLV493 data sheet states a maximum of 1T.
Our magnet is approx. 1-2mm above the TLV493D.
Can you please clarify if this magnet is suitable.
Leon
George_T
50 likes received First question asked 250 replies posted
Hello Leon,
The mentioned magnet is suitable for this application.
The detected magnetic field at a position of 2 mm will be much lower than Bmax  mentioned in the datasheet.
The same can also be verified using 3-D simulation tool.
George
George_T
Hello Leon,
George
kinetic
George,
thank you very much for your reply.
Leon
