Measure CO2 When It Matters - Infineon’s XENSIV™ PAS CO2 now comes in SparkFun Red. Check it now!
tjt22
First question asked Welcome!
I'm trying to integrate this library on an embedded software and wanted to know if there's documentation for it. In the zip file, there's a shortcut named Documentation.pdf, but when I click it, it doesn't do anything. I mainly need to know if there's an example script that I can run to verify everything is installed correctly. Thanks!
This is the link I downloaded the software from:
https://www.infineon.com/cms/en/product/gated-document/xensivtm-tlx493d-generic-library-software-554...
Neo_Lu
50 replies posted 5 likes given 100 sign-ins
Please extract all the files under the software you have download, and you can open the "Documentation HTML" and "Documentation PDF" under the file "TLx_generic_lib_core_v1.3" and "TLx_generic_lib_xmc1100_drivers-v1.3", these documents will help you understand "TLx493D 3D Hall Sensor Generic Library".
Hope that will help you,
Neo  Lu
Neo_Lu
Neo  Lu
