公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
Doublemint
5 replies posted 5 questions asked 10 sign-ins
Dear Infineon engineer,
The operation manual for the AUIR3241S model downloaded from the official website instructs to manually set two parameters named 'TAMB' and 'TECH_VAR'.
However, it did not provide information on where to modify them in OrCAD Capture CIS or Pspice.
I attempted to modify them at location 'Edit Property', but I couldn't find the corresponding parameters. The circuit schematic and error message are shown below.
Your help with this matter is invaluable to me, and I thank you in advance.
Doublemint
0 点赞
1 解答
Xiangrui
500 replies posted 250 solutions authored 50 likes received
Hi Doublemint,
These can be modified in command window as in following pic.
Xiangrui
在原帖中查看解决方案
0 点赞
2 回复数
Xiangrui
Hi Doublemint,
Xiangrui
0 点赞
Doublemint
hello Xiangrui
Thank you for your support and assistance, I have overcome this issue.
0 点赞
