公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
雪不大
First solution authored 25 replies posted 10 replies posted
怎么计算?
0 点赞
1 解答
niel
Distributor - Intron(GC)
5 sign-ins First comment on blog 10 replies posted
内部有一个上拉电阻,外部可以配一个电阻配合高压二极管的压降和IGBT的压降计算。
在原帖中查看解决方案
0 点赞
8 回复数
niel
0 点赞
niel
0 点赞
等风来123456
内部室友一个恒流源,通过电阻来计算这个电压的!!!
0 点赞
ZERO_GO
Level 6
Level 6
5 sign-ins Welcome!
0 点赞
阳东
10 comments on blog 5 comments on blog First comment on blog
mark
0 点赞
liliWinner
Level 6
Level 6
500 replies posted 250 replies posted 100 replies posted
0 点赞
User22064
10 sign-ins First like given 5 sign-ins
学习了
0 点赞
SILENCE
5 comments on blog First comment on blog First solution authored
The DESAT voltage is compared to an internal reference voltage. The result of this comparison is available by reading bit SSTAT2.DSATC.
0 点赞
