公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
mjl-0708
Hi: I used the solution provided by this link. After download the img, two FX3 unknown devices appears in device manager.
But when I update the driver , pop the message" i can't find the driver".
Is the program is tested?
https://community.infineon.com/t5/USB-superspeed-peripherals/USB3014%E5%90%8C%E6%97%B6%E4%BD%BF%E7%9...
0 点赞
1 解答
JiangJing
First like given 250 sign-ins 250 replies posted
    You can refer to the following thread post first:
https://community.infineon.com/t5/USB-superspeed-peripherals/Can-i-redirect-CyU3PDebugPrint-message-...
It offered some solutions for slavefifo.
在原帖中查看解决方案
0 点赞
3 回复数
JiangJing
   Are you using  AN75779?  If you want to add CDC interface to UVC application?
0 点赞
mjl-0708
No.I use slaveFifoSync(AN65974).
I dowanload the SlaveFifoSync.rar file from the following link.
0 点赞
JiangJing
0 点赞
