TLE92464 SPI
公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
轩富豪
5 sign-ins First reply posted Welcome!
When sending any command using SPI, the data read is 0x8500. Why is this?
0 点赞
1 解答
Xiangrui
500 replies posted 250 solutions authored 50 likes received
Hi 富豪,
Refer to datasheet:
0x8500 means no error if you are in reset state.
Please check if you are in reset state according to datasheet 20.
Xiangrui
在原帖中查看解决方案
0 点赞
3 回复数
Xiangrui
Hi 富豪,
Refer to datasheet:
Xiangrui
0 点赞
轩富豪
Thank you very much for your reply.
The problem with SPI has been resolved
I have another problem now: I can output the current normally, but I want to read the current value, and the value I read is always zero, which is why?
I look forward to your reply.
0 点赞
Xiangrui
Hi Fuhao,
Thanks for the question.
But it's better to create a new discussion for current sensing.
And please check and provide your schematic (refer to figure 21) and current supervision steps, i.e input and output SPI commands (refer to figure 22) in new discussion, if needed.
Xiangrui
0 点赞
