公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
小4代
5 replies posted 10 questions asked 5 questions asked
在使用英飞凌的TLE92108-232QX这款H桥驱动芯片的时候,发现有个寄存器的配置是这样描述的: Bridge driver passive mode 0B :Bridge driver is in active mode 1B :Bridge driver is in passive mode (Default) 这两个模式是指什么意思呢?
0 点赞
3 回复数
harvis
10 solutions authored First like received First like given
The low-side MOSFETs LS1, LS2, LS3 and LS4 can be controlled when the bridge driver in the passive mode. All the other MOSFETs kept off by the passive discharge. 简单理解"passive mode"功能比较简单,"active mode"功能比较丰富。
0 点赞
witness24
First like received 25 replies posted 10 replies posted
我的理解是例如电机,当处于torque模式的时候,可以理解为active模式;而当MCU走下电流程,即开始主被动放电,这个模式就是passive mode。
0 点赞
wulana
字面意思 是主动和被动?
0 点赞
