公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
Sean_8
当我将uIO-Stick插入计算机时,打开“IFX-MOTIX MCU Bootloader”应用程序,按钮“连接”是灰色的,无法点击,uIO-Stick上的ACT灯此时闪烁黄色。
0 点赞
1 解答
LinGuohui
500 replies posted 50 likes received 250 solutions authored
可以尝试使用老版本的BSL_tool。
在原帖中查看解决方案
0 点赞
3 回复数
LinGuohui
首先,你需要确认Uio stick固件的版本,Uio stick 处了支持MOTIX MCU外还支持其他的诸如Gate driver等产品,所需的固件也是不同的。可以使用软件Config Wizard for MOTIX™ BLDC Motor Gate Driver ICs获取当前工具版本
BSL_Tool需要版本为1.1.x的固件
其他版本固件需要更新固件,通过运行UpdateBSL.cmd更新固件
0 点赞
Sean_8
刘工好,运行UpdateBSL.cmd这步也做了更新的。
连接上电脑截图如下:
[image: image.png]
Best regards!
Yongfeng Feng(冯永锋)
Valeo Visibility Systems - Wiper Systems
Cell phone: (+86)19945714705
E-mail: yongfeng.feng@valeo.com
No.2281 JianChuan Road, MinHang District, ShangHai
*This e-mail message is intended for the internal use of the intended
recipient(s) only.
The information contained herein is
confidential/privileged. Its disclosure or reproduction is strictly
prohibited.
If you are not the intended recipient, please inform the sender
immediately, do not disclose it internally or to third parties and destroy
it.
In the course of our business relationship and for business purposes
only, Valeo may need to process some of your personal data.
For more
information, please refer to the Valeo Data Protection Statement and
Privacy notice available on Valeo.com
0 点赞
LinGuohui
可以尝试使用老版本的BSL_tool。
0 点赞
