公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
10 sign-ins 5 sign-ins First reply posted
SAF-XE164F-96F66L AC   Will it be discontinued
0 点赞
1 解答
Roy_Liu
First comment on KBA 10 questions asked First comment on blog
Yes, last order date will be the end of Feb 2024. Recommended replacement is https://www.infineon.com/cms/en/product/microcontroller/legacy-microcontroller/legacy-8-bit-16-bit-m....
Roy Liu
在原帖中查看解决方案
0 点赞
3 回复数
Roy_Liu
Roy Liu
0 点赞
1337527319
The email you sent me is the end of February 2024, and the forum response is the end of August 2024. Which one should prevail? Thank you for your reply
0 点赞
Roy_Liu
Feb is the last order date, Aug is the last delivery date.
Roy Liu
0 点赞
