公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
lu
5 sign-ins First like given First question asked
I used LTspice software to simulate the circuit and encountered some problems when importing the model document of transistor BFP842ESD. The document did not clearly label the pins, and the pins were represented by numbers. I don't know how to correspond the numbers to the corresponding B C E (Base, collector, emitter).
The other transistor BFR181 I mentioned was also not clearly labeled with pins
 I don't know how to determine the pins corresponding to these numbers, so I can't simulate them
And other models provide clear correspondence between numbers and pin labels B C E
0 点赞
1 解答
yifei_y
25 likes received 100 solutions authored 100 sign-ins
Some parameters can help to identify pins. An example is as follows.:
B - 2
E - 3
C- 1
在原帖中查看解决方案
0 点赞
1 回复
yifei_y
B - 2
E - 3
C- 1
0 点赞
